Good day guys.
I recently converted my n54 to Maxxecu, which replaced the stock MSD80 DME, as far as I know, we have a purge valve to let intake suck all the gas vapour in tank to equalise pressure difference due to gas evaporating, and DMTL pump or charcoal canister only in Euro versions to pump fresh air in to avoid vacuum. It was handled by DME, however now its no longer there, I wrote a logic in my new ECU to activate the purge valve if some conditions are met (MAP < -8 psi and pedal position < 1%), this will make sure the intake can suck excessive pressure in tank, however I have no idea where can I vent fresh air in, my thought is there might be a check valve or similar mechanism that either I can mount to esxiting ports for charcoal canister / DMTL system as I can remove them anyways, or if I can still utilise stock system (Hopefully).
I appreciate all your help, thanks guys.
