Electronic Brake -> Do we really even need it?
etropic
16
Assuming you don't actually need to use it to park on a hill somewhere...
Is it even necessary?
What happens if you leave the actuator unplugged? Will it trip something as an error? I can try it easily enough (will do next pad replacement).
If it does trip a code I wonder if the plug can be shorted or soldered such that it would always read at it's base state (assuming it's some sort of load reading and not a logic chip).
I always seem to struggle with pad replacement at the track because it's in the way and not easy to put back on after the caliper is mounted.
pbondar
458
261
You need it to comply with road based regulations in almost all countries..if it’s a track only device then who cares..
etropic
16
Great.
Now I can't wait to unplug it.
However... since it fits on the end of the caliper so nice, if I left it off, does that expose the piston to unwanted dirt?
Maybe I could modify it (cut it in half) to preserve the seal and not have the rest of the actuator in the way.
billj457
24
18
There's an o-ring and c-clip in there but a block-off plate of some sort would be beneficial:
bob20124
2011 Z4 35I
If you disconnect the actuator besides the fault alarm, the cruise control will not engage.
etropic
16
Thanks for the heads up.
Can this be coded out? I'm thinking that, like the brake sensor, the signal could be wired in a way to always show ready. But not sure if there is logic going back to something.
