Electric Water Pump Coding
Dumaurier7
690
315
Hello all, I am currently working on a project which will require an S55 DME to control and N55 which uses the electric engine coolant water pump, anyone done anything like this before? The S55 DME has two outputs for the A2W IC circulation pump and the turbo coolant pump, either of which I think I can use if coding in the engine water pump control is not possible. Based on what I've read, all the tables are there they just need to be turned on, anyone have any information or guidance on how or if this may be possible?
