E9X/E8X 215mm Billet Diff Cover
Whitbread
18
20
09 335D
Hello everyone, I've had a number of request for an aftermarket diff cover when doing LSD installs so here it is! The first run of 5 are in the CNC as I type! The cover hangs about 1" lower than stock and the finned area was purposely kept narrower than the OEM BMW 650i cover that often hits the exhaust. This cover also does not require a spacer like the 650i unit does when installed in an E9x. This cover will only fit the 215mm large pumpkin differentials. If there's enough demand, I could make a cover for the small frame units.
All hardware as well as a magnetic drain plug are included. Price will be $449 when purchased with an LSD install and $549 when purchased alone.
Obviously the pictures below are of the SLA resin printed unit that was used for test fitting :).
