These are the torque specs for the front vertical, front and rear underbody chassis reinforcement bracing torque specs. They are PITA to find, but I found them.
FRONT SECTION:
1. The front bolt that fastens the two diagonal v shaped vertically oriented bars that meet in the center of the sub-frame - right in front of the engine bottom and protective plate:
56Nm
2. The first and last big ass bolts that fasten the left and right reinforcement brace bars to the sub-frame:
100Nm Plus 90º or as close as you can.
3. The middle mid sized bolts that are in between item #2 above:
50Nm
REAR SECTION:
1. The 18mm center bolt that fastens the two rear chassis reinforcement bars to the body right behind the differential:
100Nm plus 90º or as close as you can.
2. The 18mm bolt at the end of the two rear chassis reinforcement bars that fastens those bars to the side rocker panels under the doors:
3. The 16mm middle bolt on the same bars under that fasten the bars directly to the underbody:
66Nm
4. The smaller bolt next to the big ass center rear bolt that fastens the two rear chassis reinforcement bars together:
66Nm
There... son of a bitch. Now e93 owners never have to spend days looking all over the internet for those specs. Bentley is a POS when it comes to e93 data.
FRONT SECTION:
56Nm
50Nm
REAR SECTION:
66Nm
66Nm
