Posting my current project
E82 going single jingle
Speed tech kit and VS 6766 eventually want a 6262 or 6462 but I purchased with this size turbo
I currently have all hot parts installed and port injection installed now I’m fighting a charge pipe I purchased with stripped out map sensor hardware smh I ended up retapping and threading it up and put in the stock 2.5 bar I have a 3.5 bar with harness ready but I’ll be upgrading charge pipe later when that is needed
My current goal is to start and drive the car on waste gate because I also have a 6 speed swap going in !
For fuel the ultimate goal is my dual 450’s on E85 I have a reflex kit and also ethanol sensor already in the works I want to start the car and drive it make sure engine and kit and hardware is driveable before tuning and dialing in because I’ll be honost the cars stock auto trans started slipping on the twins when I had it on MHD stage 2
Anyone able to help out with plumbing ideas so that I can start the car and move on to the 6MT swap THEN I’m looking and tuning it . No point in tuning it now with so much changes still needed
Anyone able to help with my 4 port Mac selenoid and how I can get it on wastegate ?
Pics below of build process !
