E82 135i DCT to Manual Swap question
ganque
60
15
BMW 135i N55 DCT pure stage 2
Hi everyone,
We are doing a DCT to Manual Swap to a 2013 BMW 135i N55. But need to code the car to delete EGS via VO Code.
Can anyone share the VO Code list for a manual 135i? And also which modules need to be coded after changing the VO.
(In case you are wondering, the car is being swapped because it's a Drift car, and DCT are OK for this, but the owner wants to have a clutch pedal and more rev control.)
Thanks in advance
2,255
806
Hey mate if I remember correctly the easiest way to do this is to find a car for sale in the spec that you need. Use a VIN decoder to see all of the VO codes
Its the same process going from Auto to DCT or DCT to auto or Auto to manual so if you can't find anything else to rely on go with any of those guides; they should be pretty close to what you need.
Bnks334
530
343
Looking to have the same conversion done. How much would labor set me back?
This isn't something you pay to do. Just sell the car. To get this done at a shop would be crazy. Swapping transmission, pedals, hydraulic lines, harness, repining and wiring modules, modifying the driveshaft, Coding... I can't even imagine what a shop would want to charge you. You're taking apart half the car.
That4chanhackerguy
67
10
reset variants in the DME INPA>Status>Live Data>Digital>Variants>reset Variants>All
remove $2TC from the VO
write FA to NFRM and CAS
default code (SG_Coderien) JBBE, DSC, KOMBI, CAS and FRM.
