Been chasing an issue where decel lambda will act odd.
Have had injectors sent out and serviced. All came back with no leaks, proper spray pattern, flow consistent across all of them.
Bank 2 will lag to reach 234.95 and sometimes fluctuate just below it.
Bank 1 used to behave properly but ever since rerouting lines for external catch can it has started to fluctuating around 50-100 until first hard pull then it will go back to hitting full lean instantly off throttle. Bank 2 also behaves better after aswell.
Both banks seem better if decel take place during stronger vacuum above 4000rpm
All new 02 sensors. Have reset adaptions several times threw mhd and pro tool.
Cleaned valves with no change
smoke tested and pressure tested for leaks.
last insepction of turbos showed no signs of oil leaks or play.
No smoke on decel or under load but was chasing a decel smoke issue that was a faulty check valve so possible that it fouled sensors.
No misfires or hard starts timing corrections minimal underload.
Fuel pressure seems good
Afr hits target with fuel trims staying under +10 during wot
Leaning towards somthing to do with the pcv/crankcase system but kinda hitting a wall.
17t e45 23psi DI only
