In the middle of relocating my coolant tank and have hit a snag. My plan was to remove the 3-way fitting on the pump outlet and replace with a 90. To my surprise I cannot find a part number for a 90 fitting. I have just found a 45 made by Dorman. Does anyone know of a part# for a 90 fitting? I should have just plugged the 3-way! I can probably use the 45 but it would put tension on the hose and I would have to file off the tabs on the connector to orient it correctly. On the drivers side I just T’d into the line. What to do?
