i've installed the hardware and I am down to patching the CIC with new certificates to match my vin. My 6fl works, it has my car's vin in it programmed with tool32.
I have two problems.
1.
I can't get the shell script to work on a USB drive. I've tried all of them I have here includig a 16gn jobby that's got to be near ten years old. What flash drive have you used that I need to buy in order to run the intel123 1b file script?
1a. Can I check the functionality of the glovebox USB to make sure that it's not a cabling issue? I did use the cable that came with the CIC from the donor car.
2.
I cannot find a working copy of fstool. I've installed it, copied all the files that the batch file failed on, fixed the dll erros and gotten it to open.
it fails when I click connect with a can't reach the carserver error.
it did include another batch file to start it /in psdz mode, but that seems to do nothing as well.
It does give me the options to use the can bus, which is where I need to be because I've only got a kdcan cable.
it is fstool version 2.0.2.1
I have not patched the cic enet into the obd port yet. Should I just do that and do all of this via ethernet?
there's so much misinformation and thirty two different versions of the instructions that wading through the actual data is a PITA.
I'm just looking for someone that has the software versions known to work and some basic instructions.
I'm an it nerd, so com[puter skills are high, but this is my fisrst go with all the fsc nonsense and while I understand the concept the nuts and bolts of actually accomplishing things seem to be lost.
tl;dr
need help patching FSC certificates to my cars vin so i can activate the navigation/sirius/combox things.
1.
2.
tl;dr
