Ad: BURBLE ON THE FLY via MG Flasher for B48/B58!
Jarek@mgflasher
98
28
Canada
mgflasher.com
340i B58
We are happy to announce that we have developed a special option for all B48/B58 owners called “Burble On The Fly”.
With this function, flashing your car every time you want to adjust the intensity of the burbles will be a thing of the past! Via a simple combination of the Driving Experience Switch and the MSA button you can change the intensity of the burbles ON THE FLY!
There are 4 switchable levels available.
With some feedback from our Betas we have also added "Burble OFF Mode" for those of you who want to remain in Sport and Sport + without burbles active.
Watch our instructional video to see how it works!
• To apply lower/1st level - switch to ECO Mode and push the MSA button twice within 2.5 sec and return to Sport or Sport + mode to hear the changes
• To apply higher/2nd level - switch to Comfort Mode and push the MSA button twice within 2.5 sec and return to Sport or Sport + mode to hear the changes
• To apply highest/extreme 3rd level switch to Sport Mode and push the MSA button twice within 2.5 sec and return to Sport or Sport + mode to hear the changes
• Burble OFF mode - Switch to Sport+ Mode and push the MSA button twice within 2.5 sec – NO Burble at any mode!
• To revert back to your stock/default settings (depending on your slider positions) you must simply hold the ESP button until it is fully deactivated then push the MSA button twice within 2.5 sec.
The burble level adjusted by the Aggressiveness Slider during your last OTS map flash will be the default aggressiveness adjustment without any of the above mentioned selections. This "default" mode will be activated each time when vehicle is started after sleep mode.
This option is also available for custom tunes and is enabled with the purchase of a flashing license.
Dynamic Burble On The Fly” will be released with the next MG Flasher update.
Stay tuned for more!
