Just got the BOV adapter and tried to install. Had to reverse half way into the install because the supplied parts are incompatible with the RB OCC PCV bypass kit.
1. RB OCC lines use 6 AN - the BMS BOV supplied nipples are much smaller than this so you cannot use the OCC line on the BOV nipple. You must go look for a bigger nipple size that will fit the RB OCC line.
2. The supplied TiAL BOV connector and hard plastic line is smaller than the stock TiAL line, you will be reducing your inner diameter if you use the supplied Tial connector and hard plastic line.
If anyone wants to buy this kit off me, I am selling it for $50 plus shipping. I bought the Tial BOV kit and not the basic kit.
BMS, please update your technical details so as to prevent more people like myself from ordering and getting a surprise as I did today. If you offer refunds, I will be glad to send this back, if not, I guess, live and learn. It will sit on my shelf until someone offers to buy it off me.
Very disappointed. Was looking forward to testing this unit against the current Vader set up I have which uses the same inner diameter BOV line as the stock TiAL line.
This is the extent of my review.
Update: i don't think you can buy another nipple that will fit inside the thread hole that will also be 6AN output...it looks like the thread hole is itself right at 6AN. I will try ACE to see if there is any in 6 AN thread to 6 AN nipple.
Update: as suggested by fellow member, the fitting is 1/8 npt to 3/8 barb, available at ACE Hardware, not Home Depot or Lowes. Also can order from Amazon.
