BMW Performance Steering Wheel Installation
4,340
For anyone who is piecing this kit together or has lost/broken piece, I managed to collect these while searching for one myself. Credits to rsofronici, awt and @AzNdevil for the part numbers.
- 61122212796 - wire harness
- 61138364646 - Covering cap, 12 pol. connector (Tyco 1-967415-1) (to PSW Control Unit)
- 61138364664 - Connector, 12 pol. female (socket), (Tyco 965776-1 B) (to PSW Control Unit) (A6)
- 61350444602 - Control Unit (PSW) (P-Lenkrad) ($139.45) (61 35 2 212 797 for V2)
- 61138373575 - Connector, 2 pol. male (pin), (AMP 1-968654-1) (to OBD II) (A5)
- 61319122381 - Coil spring cartridge (Slip ring) (w/additional 3-wire cable from top)
- 61136954518 - 12-pin that goes into the slip ring (Green but same connector)
1. Disconnect your Battery and make sure your (-) Negative terminal will not be touching battery
2. Remove lower plastic panels on both sides (passenger/driver). I just have picture of the passenger side
Driver side:
3. Read PDF instruction and unplug Blue connector
4. Reales the side tabs and pop off the Black/Grey connector that is inside the Blue one.
5. Read PDF installation and remove Blue/Red wire from Pin1 and Red from Pin2. Insert A3 into Pin1 and A4 into Pin2. Now install wires that you removed from Pin1 and Pin2 into Connector E
Pulling out wires from Pin1 and Pin2
Connector E
Wires from Pin1 and Pin2 inserted into Connector E
Wires A3 and A4 inserted into big Black connector into Pin1 and Pin2and Connector E connecter to A5
6. Now you can install Control Module B and connect A6 to the module
7. Attach module B to the harness using zip-tie like i did or somewhere else ... it is not the best spot because it make a bit hard to install plastic cover at the end.
8. Install the Black connector into Blue connector and then reinstall Blue connector. I used zip-tie to get all those wires together ...
9. Now you need to remove your Airbag. Make sure you have no power going to your car or it can be very bad and dangerous !
Use medium size flathead screwdriver and insert it into very little openings (one on each side)
Insert screwdriver like this
Not like that
Push on it with the moderate force and pull that side of the airbag gently
Then do the other side
Now you can open Green and Black clips/locks with a flathead screwdriver. Take it easy and don't break them
10. Disconnect the connector from the Coil spring cartridge (Grey/Yellow and Black)
11. Now you can remove your old steering wheel by using 16mm or 5/8 socket
12. Now we need to remove upper/lower steering column trim. Pull the upper part first. Pull it up and do one side at a time. You can use a medium size flathead screwdriver and push it up from the inside, but be very careful and don't punch yourself ... it hurts like a B... trust me
Tape the upper part to the dash
13. Remove the lower part by pressing on the tabs (one on each side)
14. Now remove Coil spring cartridge with T15 torx. Unplug Black small connector on the RT side(This connector was not black on my car, it was white and it was 12 pins).
Make sure not to pull the whole assembly out of the column. Very Important. Unclip all the clips and remove just the Coil spring cartridge and nothing else. These are the clips that are holding it on the side, so make sure to unclip them
15. Install the new Coil spring cartridge that came with you new PSW. Don NOT connect the Black connector just yet(Again, this connector was not black for me, and my replacement connector was blue since my steering wheel did not come with the A7 plug).
16. Now you need to remove the center console to rout the harness to the steering column. I did it this way but you might decide to do it differently.
17. This is how I routed A7
18. Read PDF instruction and remove wires from the Black connector ( the one I told you not to connect to your new Coil spring cartridge) and insert them into A7 white connector. They are numbered 1-6 and you need to insert them the same way ... #1 from Black connector goes to #1 in A7 White connector and so on ... Keep in mind there will now be un-used wires in the old connector which will just dangle there if you have a 12 pin connector like me.
Now you CAN connect A7 White connector into you new Coil spring cartridge
19. Zip-tie the wires together and put back steering wheel column trim.
20. Transfer everything from your old wheel to your new PSW and install everything back. Read the PDF file. Connect black connector from the new Coil spring cartridge to the Green connector on you new PSW. The rest is the same. In PDF file it says to connect Black connector to Black but it is actually Green and not Black. Just FIY. In fact, I wouldn't trust any color schemes in this guide as I found them to be inaccurate.
It should look like this
21. Since OBDII port doesn't have two needed wire to connect A1 and A2 I decided to use cigarette lighter as the power source. I have something else taped into this power source so don't pay attention to the Red and Black wires. You need to tap A2 Braun wire in to thick Braun wire and A1 Green/Braun into thick Red/Black wire on your cigaret lighter connector.(The pins on the CAS harness the guide wants you to tap for power don't match the color of wires either. Instead of a green and brown wire in pin 1, mine was red.
22. Now you can put everything back together. Connect your battery after you are done with everything, start your car and you should get this
  • perfwheelinstructions-1.pdf
  • electric_v2.pdf
2,255
806
Ive been wanting to eat one of these for ages but Ive read that they dont play well on 335i DCT cars. Im hoping someone here could confirm ?
4,340
I heard about problems with the M3 and DCT. Has something to do with the memory of the wheel not being retained because of the way it receives power, there was some sort of fix for it though, think it required you use a fuse tap for power instead of the recommended wire.
Reactions: aus335iguy
tan_rich
89
18
335is
Do you recall which fuse it would tap to? Recently looking up to do this myself but also read about the memory issue.
4,340
I see your post now. I do not recall, but I will be updating this thread once I find out. DCT swap should happen in the next couple months, hopefully sooner.
Reactions: tan_rich
tan_rich
89
18
335is
I see, if its just a simple tap for power. There's plenty of other nodes we would be able to tap into. For example i tapped into my door locks to power my dash cam though i may change this in the future as it gives me a DME power consumption error or something of the sorts. But it will prob give an error any tap as its detecting an unknown power drain.
Oooo, very nice. Good luck on the DCT swap. I was contemplating doing a manual swap from the DCT at one point but looking back i just think why?
Thatlow335iTO
Driver side:
View attachment 17580 View attachment 17581
Connector E
View attachment 17583 View attachment 17584
View attachment 17579 View attachment 17585
View attachment 17588 View attachment 17589
Not like that
View attachment 17596 View attachment 17597 View attachment 17598
View attachment 17601 View attachment 17602 View attachment 17603
View attachment 17604View attachment 17605
View attachment 17607 View attachment 17608
View attachment 17609 View attachment 17610 View attachment 17611
View attachment 17556 View attachment 17557 View attachment 17558 View attachment 17559 View attachment 17560
View attachment 17561 View attachment 17562 View attachment 17563
View attachment 17565 View attachment 17566
View attachment 17567 View attachment 17568
View attachment 17570 View attachment 17571
Where did you order the parts from? Like the control module and harness. Thanks
