hey all,
what's the best lpfp upgrade running on a stock ekp? I've seen that some folks even have voltage problems running a walbro 450 - let alone a dw400 or wb525; although I'll only be running 93 pump so my flow probably won't be as high as it would be with any ethanol.
fuel it has a stage 2 upgrade listed where the stock lpfp is retained and a second one is added alongside, turned on using a hobb's switch.
I want something that will be easy and reliable -- if the parallel + hobbs switch setup requires a lot more involved tuning + troubleshooting then it probably isn't worth it to me.
thanks
thanks
