Mods List:
Engine and Transmission:
Dinan 4.6L Stroker S65
Dinan Tune
Dinan Intake
Dinan Pulley
OEM M3 differential
BPM Coding – Seats / Airbags / Guage
iND Custom Engine Plenum
CAE Ultra Shifter
VAC Baffled Oilpan
BlackForest Motor Mounts
Custom X pipe
Akrapovic Axelback
Braille 21lb Battery
Suspension and Brakes
M3 front and rear subframes w/ M3 Suspension and Axels
Stoptech Trophy Brake Kit – 380mm Front, 355mm Rear
PSI / Ohlins Raceline Coilovers
Dinan Front Sway Bar
Dinan Monoball Kit for Front Control Arms
Bimmerworld Rear Wishbones
Dinan Adjustable Rear Toe Arms
Turner MS Transmission bushings
Turner MS Aluminum Subframe Bushings
Turner MS Aluminum Diff Bushings
Dinan Carbon Fiber Strut Bar Braces
OEM GT4 Brake Ducts
Exterior
OEM 1M Bodywork Conversion
Revozport 1M Raze Hood
Revozport 1M Raze Trunk
Revozport 1M Raze Trunk Lip
Revozport 1M Raze Carbon Fiber Roof and Sunroof Delete
Revozport 1M Raze Splitter w/ APR Splitter Supports
Revozport 1M Raze Diffuser
Revozport 1M Raze GTS Wing
Macht Schnell Tow Straps
Wheels & Tires
19” x 9.5” Carbon Rev CR-9 w/ Toyo R888 265/30
19” x 10.5” Carbon Rev CR-9 w/ Toyo R888 295/30
TiKore Hardware
Interior
Recaro Profi SPA Seats
Revozport 1M Raze Door Cards w/ Revozport Alcantara inserts
BMW Performance Steering Wheel ( v1)
BMW Performance Shifter boot
BMW Performance E-brake boot/lever
BMW Performance Carbon Fiber Interior Trim
BMW E82 Armrest Delete kit
P3 Vent Guage
OEM 1M Anthracite Headliner and Pilars ( for sunroof delete )
TC Design Harness Bar
Scroth 6pt Harnesses
VAC Hardware and Floor Mounts
Alumalite Rear Close off Panel
