Here are my List of Mods:
- Front and rear Ground Control Coil over kit, with M3 Control arms rear. (I rebuild front coil overs 1 year ago).
- Front Camber and caster plates.
- Breyton Race GTS wheels. 18X8.5
- ESS Flash tuning. I have the handheld. You can go back to stock any time
- Magnaflow exhaust system. I will also give you the stock exhaust.
- AR Design down pipes. I have the stock down pipes also.
- Upgraded front mount intercooler. I don’t remember the brand.
- Upgraded all charge pipes with clamps. I don’t remember brand
- Upgrade blow off valves. I don’t remember the brand.
- K and N Air filter.
- Steel braided brake lines. No factory brake fluid.
- Cross drilled slotted rotors front and rear.
- Hawk HPplus brake pads. I have a set of factory pads and also
- Tires are over 60%. Michelin Pilot super sport tires.
- M-Factory LSD diff. upgraded 7/2019
- Vehicle has had been coded. The normal coding like, mirrors, turn signal, Rear diff stuff, windows, etc.
love the car. Ready to upgrade.
