FS $800 Xona Rotor turbo xr9567 ceramic ball bearing, vband
Cruizinmax
128
73
09 335i
This is a turbo I received with a turbo kit purchase. It is rated at 95 lb/min or approximately 950 crank horsepower. For those who may not be aware Xona is a partnership company between Tial and Forced Performance. It's a American made turbo, not a Chinese turbo company.
The turbine housing is a Tial V-band 1.03A/R and the compressor housing has a elbow welded on as you can see. This is the turbo that would have came in the Motiv 950 kit. I can remove the elbow on the compressor housing removed and have a straight outlet welded on if desired.
The turbo appears to be in perfect working order. No shaft play or damage to the compressor or turbine wheels are visible. The person I got it from stated it was not leaking oil or smoking.
New this would be a $2700 turbo. I'm asking $800. I'm located in SW Missouri but can ship in the US.
bloomagency
Thanks for sharing the details! The turbo sounds like a solid piece of equipment, especially with the Tial and Forced Performance connection. It's great to hear it's in good condition and has no visible damage or shaft play.
Considering it’s priced at $800, that seems like a good deal for someone looking to step up their build without breaking the bank. The option to remove the elbow and weld a straight outlet is also a nice touch for those who need it.
Just curious, would you be willing to share the specific trim and wheel size of the compressor and turbine? That could help buyers get a better sense of how it’ll fit into their setups.
Best of luck with the sale!
