Right now, the car works perfect up to 22 lb boost on my DIY tune. When I boost over 22 lbs, the boost deviation calculation does not work correctly, and I believe it is due to using a calculation of boost target RAM minus the manifold boost pressure. Manifold boost pressure maxes out at 22.5, I guess due to having a 2.5 bar TMAP.
I notice that my Wedge tune has correct values in the boost deviation log values. I also notice my other car I tuned myself (2017 540i) has correct values for boost deviation, with no special coding or changes to the standard tune.
The issue with having incorrect values for boost deviation with boost target RAM values above 22.5 lbs means that the custom P tables I use increase the WGDC even if the car is boosting ok. This leads to a runaway condition for actual boost, since it keeps adding wgdc when it should not. I can do weird stuff to fix this, but would rather get the logic working correctly.
thank you to anyone who can help. I can pay for advice on what to do, but keep in mind my goal is to finish tuning the car with a tune I can easily edit at the track to get best results.
I would like to get best effort on my Shuenk N55+ turbo, before I upgrade to a bigger turbo. Here is my best run on my N55+ turbo when the car weighs in at 4020 with driver:
